Hi i have problem error code L299 no lifting and slow moving how to fix this problem thanks
Hello
The first thing he had done was to change the pressure sensors. It did not work, so I changed the hydraulic pump and the pressure accumulator. The main problem was the hydraulic pump wear. I hope this experience helps you.
Hello,
Did you find the problem with the faultcodes?
I have the same and L306 as a bonus.
Best regards
The fault code is L272 and L299.
