Fault code 19?
Have an issue with code 19 and was wondering where I should start looking at? Any input? Thanks
  • Posted 9 Feb 2017 19:17
  • By ynot
  • joined 5 Feb'17 - 21 messages
Static Return to Off, basically incorrect sequencing of controls/startup. On the Wave, this normally means trying to operate without standing on the footpedals, having the gates open on a machine that is set to require them closed for operation, having hands on the controls when keying on or the Base/Platform switch on the service pod is set to Base. If you are doing everything in the correct sequence, you need to check footswitches, throttle/steer pots and hand sensors.
  • Posted 7 Jul 2017 21:06
  • By techno_nz
  • Canterbury, New Zealand
Sro means static return to off.
So some switch that is normally open is closed or vice versa. Typically is deadman switches
  • Posted 7 Jul 2017 20:59
  • By stam
Hi did you have any luck with this code? I have found it to be SRO but don't know what SRO means, and customer is deserpate for this to be working asap
  • Posted 7 Jul 2017 10:44
  • By Sparkplug
  • joined 9 Apr'14 - 10 messages
edition #1281 - 14 May 2026
Terberg RT403
Still GX10
Still GX10 2000
Poland
EUR950
Terberg RT403
Still GX10
Still GX10 2000
Poland
EUR950
