Fault code 135-3
We just recently purchased this lift and repeatedly get this 135-3. The service team of the company we purchased this machine off of has been out a few different times. Changed a fuel air sensor I believe and cleared code it has come back 2 different times after they have supposedly fixed it. Does anyone have any ideas on what is causing this code to be thrown.
  • Posted 8 Nov 2013 23:30
  • By josh_f
  • joined 8 Nov'13 - 2 messages
Check your fuel pressure at the fuel rail where the FAP screws in. You should have 4-7 psi at an idle under acceleration it will jump up to 12-14 psi. If you pull the orange vacuum line off the regulator you should see 12 psi
You most likely have a bad regulator with high fuel pressure. This is a common problem with the GM engines and the Teleflex GFI regulators
  • Posted 14 Nov 2013 10:33
  • By Fortis
  • joined 27 Jun'09 - 4 messages
Hi josh,
well first off according to the serial number you posted this is not a H100XM, it is actually a H100FT.
Ok now we got that straight...
The guys from the service center you had come out and look at it did go down the right track. Replacing the sensor was one of the steps. But since this doesnt seem to fix the problem i have a question.
Is this a mazda engine? or a GM engine in this truck?
If a GM engine then yes the flow chart does say to test the FAP sensor and circuit and ultimately replace the sensor if the wiring checks out ok.
But if this truck has a mazda engine then it refers to the hydraulic pressure with the mazda engine and also refers to the engine oil pressure with the 2011 GM oil pressure sensors.
So clarifying this bit of information may shed a different light on the diagnosis.
I found it curious that in the troubleshooting manual they referenced ALL the sensor circuit diagrams, maybe that's just being overly thorough by hyster engineers... i just cant say.
All in all they did start down the right track by checking the FAP sensor and replacing it though. I just think since it did not fix the problem it could possibly be a different sensor or ultimately the VSM or ECU software or something. I'm sure they checked all this when they were running diagnostics on the truck.
I have a question though...
did they send out the same tech on each of your service calls?
reason i ask is maybe you should request a different tech to come out and take a look? a different tech may have a better perspective on the problem.
One other thing also... is this truck still under warranty?
If so let them handle it... between the dealer and the factory they will get a handle on the problem and fix it... eventually...
sometimes these problems can be tricky and it takes time to work it out, especially if it is a factory issue. Just stay on top of it and don't let alot of time pass before calling them.
good luck
  • Posted 11 Nov 2013 00:46
  • Modified 11 Nov 2013 00:46 by poster
yes it is N005V03380E
  • Posted 9 Nov 2013 02:26
  • By josh_f
got a serial number?
  • Posted 9 Nov 2013 00:01
Jim Mozer Jim Mozer
Chair of Board of Directors, Industrial Truck Association (ITA)
International key account manager, Meijer Handling Solutions
Sales director - UK & EMEA, Collective Intelligence Group
Secretary general , FEM - European Materials Handling Federation
In the 13th century, the word "nice" had a negative connotation, meaning "ignorant" or "foolish". It is thought that the word gradually obtained a positive meaning in the English language where it was often used to refer to a person who was ludicrously over-dressed. The term was confused with a reference to something refined or someone who was "nicely" dressed.
Nagano NUZ090D
Manitou MH25-4
Jim Mozer Jim Mozer
