FAULT 07 STEER PMT NEC
I can't clear this fault 07 STEER PMT NEC and recalibrating steer pot doesn't make any difference. The code doesn't seem to make any difference to the operation at all but still would like to get it figured out. Any help is appreciated folks.
  • Posted 13 Mar 2015 08:39
  • Modified 13 Mar 2015 08:45 by poster
  • By troy_m
A-Lift Services -- safe -reliable -affordable
What is a "STEER SYSTEM PMI" ??
  • Posted 19 May 2017 07:02
  • By troy_m
Hi, if anything could help with fault codes of this machine. I am carlos of Ecuador and technical information have yale. thanks
  • Posted 6 Jan 2016 14:52
  • By Charly61
  • joined 29 Dec'15 - 56 messages
  • GUAYAS, Ecuador
there is no problem that has no solution.carlosgomezballadares@hotmail.com
Yes I am thanks. I wonder why the screen says "warn 07 steer pmt nec" if it's a lift pot -could it be a problem with steer motor? I've had to recalibrate the lift a few times over the past year and just discovered the ground strap was ripped off and assumed that it's building a static charge and messing with the ecm. I've had Toyota's and Clarks that are sensitive to static. Any ideas are welcome.
Thanks
  • Posted 20 Mar 2015 09:24
  • Modified 21 Mar 2015 23:04 by poster
  • By troy_m
On a E40FR truck, code 7 is a lift pot out of range, not steering. Are you sure of the model?
  • Posted 17 Mar 2015 00:36
  • By BREWSKI
Toyota 02-8FD30
Terberg RT403
