Event codes
I have a pe4500-60 that's relatively new for our fleet, got it used and it worked perfectly fine for a half hour. Wrench light comes on and lost power steering, and speed was cut back to 1mph. I went through the whole menu and saw that code 530 and 522 showed up more than any other code. Any sort of insight would be greatly appreciated, thank you.
  • Posted 11 Mar 2023 01:15
  • By Jake_Powell
  • joined 22 Mar'22 - 8 messages
  • Washington, United States
Do you happen to have a picture of the sensors so i have a better idea on what to go after?
  • Posted 24 Mar 2023 03:26
  • By Jake_Powell
Yes, they are under the handle knuckle cover.
  • Posted 17 Mar 2023 02:46
  • By marcos_m
  • joined 25 Feb'19 - 114 messages
Do you happen to know where the sensors are located? I think i found one but i could be wrong.
  • Posted 16 Mar 2023 03:36
  • By Jake_Powell
Codes only apply to units w power steering. Make sure your rps 1 & 2 are synced. Check the wiring to both sensors. If they're off by more than 6° it'll throw a code.
  • Posted 11 Mar 2023 06:30
  • By marcos_m
Sue Tomic Sue Tomic
