EV 100 SYSTEM
I have an easy issue that I'm having difficulty with. Perhaps someone can point me in the right direction. This particular truck has an EV100 system and it keeps blowing a #2 rec. Does anyone know what could be the cause? heat? another fault componet?
Thank you
  • Posted 16 Jul 2015 22:22
  • Discussion started by 7777
Showing items 1 - 15 of 15 results.
HI Guys
I have a error code #58 on a TSP 1.5TN (No Lift)
Please can someone help me
  • Posted 12 Jun 2019 21:07
  • Reply by LouisMaree
  • South Africa
thank u
  • Posted 5 Sep 2015 01:44
  • Reply by 7777
If you are looking for an EV100 used or reman controls.
Visit www.arssolutionsllc.com Ph.800-804-5711
They carry a lot of AC and DC controls and electronics components in stock.
Thanks
  • Posted 4 Sep 2015 07:28
  • Reply by pirucho
  • Illinois, United States
Hi, everyone
I have a order picker BT OE35, his trip and give me error code -49 to push in FW position and trip, and give me -53 to pull RV position and trip. I change a 1REC, 2REC, 5REC. Change the current sensor, I repair Plug A, and Plug B. Change the 3REC & 4REC change the 25 REC. And the other snubber change the position, change de accelarator potenciometer. And today I change de reactor for another they having. The motor is ok, because a hit the FW/REV contactor and after I push the 1A contactor and they we run. Thanks for your help. Sorry for my ignorance I want to learn.
  • Posted 3 Sep 2015 11:02
  • Reply by ElectTech
  • Puerto Rico, Puerto Rico
thank you everyone
  • Posted 21 Jul 2015 18:45
  • Reply by 7777
i was going to suggest to check the capacitor.
if there is any bulging around the terminals the capacitor is probably bad, it may check good with a meter but the bulging is telling a different story. One other thing to check is the spider block, i've seen those cause various problems such as this.
  • Posted 21 Jul 2015 14:23
  • Reply by swoop223
Must also "Tune Up" the Oscillator card with use of EV 100 LX handset.
It looks like a big calculator, black plastic body, with Red colored LCD numbers that appear on its screen.
Has to be plugged in to Oscillator card.
  • Posted 21 Jul 2015 14:11
  • Reply by LaGrange
  • Missouri, United States
Thank you Tech, I never checked for open or short cqt., all findings r pointing to a faulty itermitten cap.
  • Posted 21 Jul 2015 04:55
  • Reply by 7777
How are you finding the #2 SCR bad? Is it shorted? Open? Wont gate on? Leaky?... #2 SCR's should never see high current flow through them which would heat them up and cause them to fail....unless, the capacitor is shorting. Replace the cap. The 1X choke is one of two winding found in the Reactor/1X choke assembly (the big black module that says EV-100 on it)...the 1 X choke is inline with the capacitor and # 2 SCR...but I have NEVER seen one fail. I would replace the capacitor and go from there.
  • Posted 20 Jul 2015 23:53
  • Reply by Techtrainer64
  • Kentucky, United States
Thank you Edward
  • Posted 19 Jul 2015 00:36
  • Reply by 7777
load test the battery, and be sure the current limit and plugging power is properly set, make sure the screws that hold down the 'spider block' are the right screws in the right places, and be sure to do a 'shorts to frame' test on ALL the power cable connections. I would also strongly consider replacing the capacitior, just to be sure.
I would also be sure to replace all the directional and 1a contactor assemblies (not just the tips).
  • Posted 19 Jul 2015 00:31
  • Modified 19 Jul 2015 00:32 by poster
  • Reply by edward_t
Its installed properly. it would seem that when the truck gets hot then it PMT's, (jerks into 1A) codes then stops until the key switch is recycled. But #2 rec has failed 2x in the past 6 months, wondering if its TVH elec. parts
  • Posted 19 Jul 2015 00:22
  • Reply by 7777
make sure you are putting in a #2 rec and not a #5. #2 should have a red dot on it. you can use a # 2 in place of a #5 but not the other way around.
  • Posted 18 Jul 2015 23:01
  • Reply by popeye
what is the 1x choke? The #2 rec. has failed about 3 times in 6 months, the 3rd time the problem reoccured after 1 week. I haven't check the truck yet but I thinking its going to be the #2 rec again.
  • Posted 17 Jul 2015 06:54
  • Reply by 7777
How often? Two things to check...check the capacitor and check the choke winding of the 1X choke (personally never seen one fail)...also check/replace 22 filter. Thing is, bad capacitor or choke should be causing PMT trips.
  • Posted 17 Jul 2015 00:13
Wentzville, MO, United States
Harrisburg, SD, United States
Ottumwa, IA, United States
