Hi
My forklift Nichiyu 60series FB20P has an error shows text sensor speed on display panel and indicator panel on safety monitor ( for travel circuit ) is blink.
Does anybody knows the exactly the problem and how to solve this problem ?
And if sensor speed is broken where the position ? And how to remove and install.
Thank you
hai junus
banyak yang jual spare part nichiyu di indo
Hey Marc
Thank you, i found in local market with 40 USD per pcs.
Regards
Anis
hello Junus, sorry but you can't find a part from a MPU-Board separately from Nichiyu. If you want to change it you have to find it locally.
Kind regards
marcb
Hay Marc
The connector sensor is bad, I already repair.
But I found new problem that condenser on travel circuit is bad.
HCGF3A 1000MFD 160VDC 72 06. Do you know any part is similar with this ? Because in market Jakarta i have found yet.
Thanks
Hi Marc
Thank you. next day I will check.
Regards
Anis
hey junus, they are the same (part number 39530-01231)
kind regards
marcb
Hello Marc
Thank you, I will checked.
Are the 2 sensor is similar model or a couple of sensor ?
Regards
Anis
Hey Junus, there are 2 speed sensor mounted on top of the front axle. Maybe a bad connection or switch from position or broken.
kind regards
Marcb
