Error D4, D6 and Showing Engine Check Light
Hi all,
The Doosan Forklift Truck showing error D4 and D6 within 10 second after engine start and also lights up engine check on dashboard. Please help me for this.
Model: D80S-5
Serial Number: FDB0D-1270-02180
Type: D
Industrial Truck: 2F61
  • Posted 10 Mar 2022 23:03
  • By Syed
  • joined 14 May'15 - 197 messages
  • Sindh, Pakistan
swasiquehussain at gmail dot com
Dear Andrew_k,
Thanks for the error description. I need wiring/component detail or service manual so that i can easily work.
  • Posted 14 Mar 2022 16:52
  • By Syed
  • Sindh, Pakistan
I dont have a manual for D80s-5 but for a D70-5 the faults are as follows.
D4 5820 3 HIGH VOLTAGE AT
BATTERY
measured voltage at
power supply is higher
than 18 V (12V device)
higher than 32.5 V (24V
device)
shift to neutral
OP-Mode:
TCU shutdown
z check power supply
battery
z check cables from
batteries to TCU
z check connectors
from batteries to
TCU
D5 5830 2 ERROR AT VALVE
POWER SUPPLY VPS1
TCU switched on VPS1
and measured VPS1 is
off or TCU switched off
VPS1 and measured
VPS1 is still on
cable or connectors are
defect and are contacted
to battery voltage
to vehicle ground
permanent power supply
KL30 missing
TCU has an internal defect
shift to neutral
OP-Mode:
TCU shutdown
z check fuse
z check cables from
gearbox to TCU
z check connectors
from gearbox to
TCU
z replace TCU
D6 5840 2 ERROR AT VALVE
POWER SUPPLY VPS2
TCU switched on VPS2
and measured VPS2 is off
or TCU switched off VPS2
and measured VPS2 is still
on
z cable or connectors are
to battery voltage
to vehicle ground
z permanent power supply
KL30 missing
z TCU has an internal
defect
shift to neutral
OP-Mode:
TCU shutdown
z check fuse
z check cables from
gearbox to TCU
z check connectors
from gearbox to
TCU
z replace TCU
  • Posted 13 Mar 2022 07:45
  • By andrew_k
  • joined 17 Mar'07 - 363 messages
  • England, United Kingdom
Dear All,
I haven't found a solution yet please help
  • Posted 13 Mar 2022 01:08
  • Modified 13 Mar 2022 01:09 by poster
  • By Syed
  • Sindh, Pakistan
Still GX10
Still GX10 2000
Poland
EUR950
UN Forklift FBR25NQC3
Hawker Powersource, Inc.
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
