error codes
runs good, then runs poor, codes vsm 524263-1, vsm 524213-3, ecu 190-4 and ecu 168-4.
  • Posted 17 Jan 2014 00:35
  • By jimmy_s
  • joined 17 Jan'14 - 30 messages
522714-4 Mechanical Accelerator Position Sensor OORL.
  • Posted 25 Apr 2018 05:32
  • By BREWSKI
190-4 is loss of crank pulse. Cam pulse without crank pulse.
  • Posted 25 Apr 2018 05:30
  • By BREWSKI
fault code 522714-4 help
  • Posted 25 Apr 2018 04:37
  • By Palletlife
  • joined 25 Apr'18 - 1 message
  • Alabama, United States
The problem that I have is that it runs poorly but only intermittently, sometimes it runs fine. It's not misfiring. I rebuilt the Fuel Reg. and replaced the lp filter since the truck has 11,000 + hrs. Tuned up as well. Getting spark at each plug. No check engine light, but this first code I see from it's history is 190-4. I don't have the service password to erase them and I'm not getting a code at all. I believe the throttle body is getting stuck, I hear it click every time it's running poorly....
  • Posted 16 Apr 2016 03:53
  • By art_flo
  • joined 20 Jan'16 - 7 messages
You have a short between the 12 volt supply and the signal on the horn. It happens all the time on these trucks. The horn is under the step on the right hand side.
  • Posted 15 Apr 2016 22:59
  • By BREWSKI
Did you ever find a solution to the problem. I am having the same problem with a Yale GLC60 with a Mazda. Runs fine and then poor intermittently. Got a 190-4 as well....
  • Posted 15 Apr 2016 07:55
  • By art_flo
Thanks for the input. To follow up, horn blows constantly, no open here. However, their are modules/components in foot well housing?
  • Posted 14 Feb 2014 08:59
  • By 1sharpdog
  • joined 20 Apr'12 - 220 messages
David Sharp
Have a Great day and thanks for all the great advice! sharpforklift@gmail.com
I think you will find the horn has gone open circuit, it's been awhile but I think you will find it in the right hand foot well housing
  • Posted 14 Feb 2014 08:26
  • By NER045
I also have a code 524213-3, unit left in rain. Where is horn output driver? I am working on a GLC03VXN
  • Posted 14 Feb 2014 03:03
  • Modified 14 Feb 2014 03:04 by poster
  • By 1sharpdog
David Sharp
thanks to all of you, I'll check these out today. Have a great week end.
  • Posted 17 Jan 2014 23:54
  • By jimmy_s
swoop is right, also, in my experience, these codes are what sometimes get set when you have a loose alternator belt or intermittent wire connection at the alternator. (like a loose large wire that is connected by a nut, when the nut is only finger tight), or when someone tries to jump another truck with the jumper cable wrong,
Is this truck an "LPS" rated truck? if so, you may have a problem with the connection internal to the 'LPS' shut off switch that is a cable pulled switch or just someone that pulls the cable to see what it does.
hth
  • Posted 17 Jan 2014 21:36
  • Modified 17 Jan 2014 21:37 by poster
well that may be what it is, a bad battery
but there are other causes for the DTC 168-4 also
alternator failure
operation cycle too short to charge battery
Quiescent current draw too high during truck off time
As for the other codes
DTC 190-4 not in the DTC code chart
DTC 524213-3 Horn Alarm Output Driver OORH
cause
Horn output driver short to battery
DTC 524263-1 Uncommanded Power Down
cause
VSM Failure
Now of course a defective battery may trigger many codes due to the erratic voltage it may be supplying but i would certainly not ignore these other codes if the battery is found to actually be the problem and replaced.
I would try and charge the battery, check it, load test it
if pass...then reinstall it and clear codes and run truck to see if any codes return.
if battery fails then replace battery, clear codes, run truck and monitor it.
  • Posted 17 Jan 2014 21:28
Thank you very much.
  • Posted 17 Jan 2014 09:48
  • By jimmy_s
love to travel
168-4 is flat battery
  • Posted 17 Jan 2014 06:15
  • By kevin_k
Taylor TX330S
USD159,500
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
REPOWERTEK Inc
Michel Denis Michel Denis
