Error codes
Srs, I have a machine Nichiyu FB15P-65 that show the following error codes on display:
D24
A10:FET7
Somebody knows what it means? The machine have no functions (traction and Hydraulic and steering)
Any help will be gratefull.
THanks
  • Posted 13 Sep 2010 19:44
  • By goncalosousa
  • joined 12 Sep'05 - 42 messages
  • Leiria, Portugal
model: FB25PN-65-45MSF
ERROR A10, D24
Help me. I don't fingertip control
  • Posted 22 Apr 2016 01:09
  • Modified 22 Apr 2016 01:10 by poster
  • By nguyen_s
  • joined 5 Mar'14 - 66 messages
  • binh tan, Viet Nam
Hello goncalosousa, have you found the problem on your machine? I had the same problem today on a FB18PN-65 series. can you let me know something.
Kind regards
Marc
  • Posted 26 Aug 2011 00:22
  • By marc_b
  • joined 1 Jul'05 - 345 messages
  • ANTWERP, Belgium
hi sir i need help.. i have nichiyu fb25pn.
in the display panel show.. ERROR BUS SYSTEM
there is no steering, no traction, no hydraulic.
when i turn the key switch on. the main contactor do not energized, and the display panel shows Error Bus System..
thanks.
  • Posted 2 Aug 2011 22:46
  • By Jeffrey
  • joined 15 May'11 - 6 messages
  • South Cotabato, Philippines
Hello, error message D24;PC.board-AOS. if your machine is equipped with a fingertip control than you have to find the problem there, otherwise the option setting is wrong.
A10;FET7-over drive, problem with FET.
  • Posted 15 Sep 2010 23:01
  • By marc_b
  • ANTWERP, Belgium
