Error codes: -99 & -01
We are working on a Clark TMG17, when you turn the key it is throwing the code -99 and when you go to run it it throws a -01. Everything seems to be functioning properly but just trying to figure out what these mean. Any help would be appreciated.
Thanks
BTW, this is an electric unit.
  • Posted 10 Apr 2014 02:27
  • Modified 10 Apr 2014 02:28 by poster
  • By ddaar
  • joined 5 Oct'13 - 11 messages
Yep need the handset to change maintenance code to 255 and the code -01 is hand brake switch (or combination seat switch they are both in same circuit) -remove the left dash panel and under the handbrake the switch arm isn't coming in contact with the pin on the brake mechanism -I like to put a piece of hose on the pin -once you see it you'll know what I mean
  • Posted 17 Apr 2014 09:13
  • By troy_m
ev100 handset can do it
  • Posted 11 Apr 2014 20:50
Thanks Swoop, would we need a scanner or computer hookup for that or can you do that from the control panel? I haven't been out to see the machine myself, just relaying from our tech.
  • Posted 11 Apr 2014 06:58
  • By ddaar
the maintenance code is something the tech can set to warn the operator that a service is coming up. It is just a convience alert to allow you to keep the truck serviced on time. This code can be turned off by setting funtcion 19 and 20 in the controller to 0 value.
  • Posted 11 Apr 2014 06:30
  • Modified 11 Apr 2014 06:36 by poster
Any way to find out what the maintenance code is for? If it is a brush warning, any way, short of checking each motor, to find out which motor or whatever else it may be?
  • Posted 11 Apr 2014 01:16
  • By ddaar
01 could be park brake code, or deadman or seat switch depending on how the truck is wired up and type of truck it is.
99 is a maintenance alert code
  • Posted 10 Apr 2014 15:06
I think that 99 is a maintenance code. 01 is a parking brake code.
  • Posted 10 Apr 2014 12:02
  • By rogeriwt
-01 is the seat switch circuit -99 is usually a brush wear or a temp sensor but is something that goes through the truck management module and can be whatever the engineer wants it to be.
  • Posted 10 Apr 2014 07:57
UN Forklift FD35T
Taylor TT300
USD98,500
Neptune was discovered in 1846. It then took 165 years, or until 2011, for the planet to complete one orbit of the sun.
