error codes 105 and 110
Hello, i'm having an issue on a Crown SC5225-30 S/N 10119494. i installed a new access 3 purchased through the dealer. After install i'm getting two event codes. Event codes 110 and 105. Software not complatable with access 1 and no communication with access 1. i calibrated accel pot and brake pot. Still have the codes and unit won't move. needing help on how to fix the issue. Thanks in advance.
  • Posted 10 May 2023 23:58
  • By Hdsprt
  • joined 12 Nov'15 - 43 messages
  • Illinois, United States
JMC1, thank you for your response. I figured that was the case. just wanted to make sure. thanks again.
  • Posted 12 May 2023 02:47
  • By Hdsprt
You will have to call Crown to update the software.
  • Posted 11 May 2023 18:44
  • By JMC1
  • joined 8 Nov'18 - 50 messages
  • Iowa, United States
SMV (Konecranes) 12-1200B
Terberg RT403
Terberg RT403
Hawker Powersource, Inc.
