Error Code E34 Spark Control
Would anyone know what the diagnostic procedure would be to further troubleshoot Error Code E34 spark control
  • Posted 7 Mar 2018 00:39
  • By JAKE2
  • joined 7 Jul'17 - 36 messages
ANYMORE TROUBLE SHOOTING IDEA'S. HAVE TRIED THESE. STARTED WITH CODE E34 CLEARED CODE RAN LIFT AGAIN RE-CKED EACH COIL PACK. CODE DIDN'T COME BACK. ANYTHING ELSE TO CK WHAT DO U THINK I AM MISSING DID SPARK TEST ALL CYL-S FIRING ONLY THING THAT WAS DONE SPARK PLUGS WERE CHANGED BY SOMEONE ELSE. FIRST THING I CKED WERE PLUGS EVEN SWAPPED THEM OUT 2 TIMES. CUSTOMER STATED THE ONLY THING WAS DONE WERE THE PLUGS CHANGED. LIFT RUNNING FINE UNTIL CUSTOMER CHANGED PLUGS.
  • Posted 15 Jan 2020 09:58
  • By cary_s
  • joined 12 Jul'18 - 2 messages
First thing is to make sure none of the wires are broken in the coil connectors. Second is that you can start the engine and disconnect number 4,3, and 2 coil connectors and the engine will still run on number 1 cyl. Then connect number 2 and disconnect number 1 cyl. Keep moving along so you have the engine running on each cyl by itself. If the engine dies or runs rough on any cyl then that coil, spark plug, or cyl. is probably bad.
  • Posted 17 Mar 2018 07:50
  • By mwjski
  • joined 26 Jan'18 - 33 messages
  • Montana, United States
Cortney Hunt Cortney Hunt
COO, Intelligrated, Trew and Transnorm
Automation manager, N.C. Nielsen
Ncn 110TH
Ncn 110TH 2015
Maxlion FB25EH
Neptune was discovered in 1846. It then took 165 years, or until 2011, for the planet to complete one orbit of the sun.
September 29-01 October, 2026 - Cairo, Egypt
October 6-7, 2026 - London, United Kingdom
