Error code E0
Need help with error code E0 I have on Toyota electric lift 36 volts 5FBE15. The lift still drives but NO HOIST. What E0 means and what should I do to get the lift working again. Also I would like to have the explanation of all code in this lift for future need if possible. Your help is much appreciated and thank you.
  • Posted 9 Jan 2013 02:59
  • By alex_t
  • joined 21 Nov'10 - 9 messages
  • Washington, United States
HI, im having the same problem with my forklift. Did you find out what caused the problem on your lift related to E0 code? do you have a part number for the parts replaced?
Rodco
  • Posted 13 Nov 2015 02:56
  • By Rodco
  • joined 13 Nov'15 - 5 messages
RODCO LIFT
Can you point me to the most likely cause that makes the lift hoist not working after checking the fuse? My email is alextare33 at yahoo.com. Thanks
  • Posted 9 Jan 2013 15:02
  • By alex_t
ERROR CODE EO: MAIN MATERIAL HANDLING CIRCUIT ABNORMALITY
1 Pump fuse (F2) blown
2 TMP defect
3 Main material handling circuit connection defect
4 Open circuit, connector disconnection or defective contact in RAP wiring
5 Disconnection or defective contact of wiring between TMP and DCISDD
6 Disconnection of wiring between CPU and DCISDD
7 Defective contact of each connector
8 Material handling DCISDD board defect
9 CPU board defect
Might help to post an email in your profile for future refrence in case anyone had info to send you..
  • Posted 9 Jan 2013 08:27
  • By kevin_t
Enforcer FLBAXT25
Maxlion FB30LI
