Error code E0
Need help with error code E0 I have on Toyota electric lift 36 volts 5FBE15. The lift still drives but NO HOIST. What E0 means and what should I do to get the lift working again. Also I would like to have the explanation of all code in this lift for future need if possible. Your help is much appreciated and thank you.
  • Posted 9 Jan 2013 02:59
  • By alex_t
  • joined 21 Nov'10 - 9 messages
  • Washington, United States
HI, im having the same problem with my forklift. Did you find out what caused the problem on your lift related to E0 code? do you have a part number for the parts replaced?
Rodco
  • Posted 13 Nov 2015 02:56
  • By Rodco
  • joined 13 Nov'15 - 5 messages
RODCO LIFT
Can you point me to the most likely cause that makes the lift hoist not working after checking the fuse? My email is alextare33 at yahoo.com. Thanks
  • Posted 9 Jan 2013 15:02
  • By alex_t
ERROR CODE EO: MAIN MATERIAL HANDLING CIRCUIT ABNORMALITY
1 Pump fuse (F2) blown
2 TMP defect
3 Main material handling circuit connection defect
4 Open circuit, connector disconnection or defective contact in RAP wiring
5 Disconnection or defective contact of wiring between TMP and DCISDD
6 Disconnection of wiring between CPU and DCISDD
7 Defective contact of each connector
8 Material handling DCISDD board defect
9 CPU board defect
Might help to post an email in your profile for future refrence in case anyone had info to send you..
  • Posted 9 Jan 2013 08:27
  • By kevin_t
Bohl and MH Equipment join forces Peoria, IL, United States
edition #1302 - 8 October 2026
In this week’s Forkliftaction News , we have two stories reminding us of the power of a generous spirit... Continue reading
Aichi SR18A
Toyota 8FD30
Singapore
USD18,000
Venus is the only planet in our solar system that spins in a clockwise direction. One day on Venus is 243 Earth days long, which is even longer than its year, which takes only 225 Earth days.
Aichi SR18A
Toyota 8FD30
Singapore
USD18,000
March 16-18, 2027 - Stuttgart, Germany
October 26-27, 2026 - Fort Shelby, Michigan, United States
