ERROR CODE E 47
I got a Mitsubishi FB15KRT with Error code E 47. I do not have a service manual
  • Posted 20 Jan 2015 08:13
  • By nebojsa_d
  • joined 20 Jan'15 - 3 messages
  • Serbia, Serbia
try to set the settings to default. we just fix the error e47. we discover that the hydraulic motor controler got burn inside cuz the 1 line is loose. and we change the controller but got the same Error code. after we set the settings to default the forklift work nomally.
  • Posted 27 Mar 2017 23:04
  • By justin_d
  • joined 27 Feb'16 - 28 messages
  • RIYADH, SAUDI ARABIA, Saudi Arabia
Kako mogu do Vašeg maila g. Nebojsa? Mene možete kontaktirati na kandi et vip.hr
  • Posted 22 Mar 2017 07:16
  • Modified 22 Mar 2017 07:16 by poster
  • By Kandi
  • joined 22 Mar'17 - 2 messages
  • ., Croatia
Kandi "Pump Motor Open"
contact me on mail
  • Posted 22 Mar 2017 06:20
  • By nebojsa_d
  • Serbia, Serbia
Hi,
I have the same problem. I have bought Mitsubishi FB15KRT-PAC from the year 2010. and sometimes it go normally, but sometimes it will go only a half meter forward or backward and then stops. And there is red light on control panel and it shows error E47.
After you switch main switch on/off several times, it goes again normally for maybe obe or more hours anf then again the same problem.
What to do?
  • Posted 22 Mar 2017 03:58
  • By Kandi
  • ., Croatia
ohh. i see that on caterpillar forklift. and mitsubishi is kinda the same. but the model im talking about. sorry i ddnt metion. it is FB15KRT-PAC and it doenst have like that. but this is a big help for me. thank tho.
  • Posted 27 Jun 2016 23:25
  • By justin_d
justin1404135@gmail.com
no the D1L diode is located on the control panel along beside where the IGBT's are on the shunt bars, should be a small black box looking component that is screwed down to the heatsink and connected inline with the main pos power shunt bar.
There will be 3 of these side by side, the one fartherest away from the logic card assy is D1R, the one next to it is D1L, there will be a space between this one and the one closest to the logic card assy which is D1P.
  • Posted 27 Jun 2016 22:45
hmm. sorry. where can i trace this D1L diode? is it inside the traction motor?
  • Posted 26 Jun 2016 20:51
  • By justin_d
Left armature diode, abnormality
check the D1L diode
check the wiring between the D1L and CS2 current sensor
also check the CS2 current sensor
if no problems found then logic is bad, replace logic
  • Posted 2 Mar 2015 02:43
edition #1289 - 9 July 2026
In this week’s Forkliftaction News , we continue our coverage of CeMAT Australia with a report on how the lack of local after-sales support and service is hurting new foreign entrants into the Australian market... Continue reading
Cameron Paxton Cameron Paxton
President and chief executive officer, Toyota Material Handling Australia (TMHA)
President, Doosan Bobcat North America
Chairman of the board of directors, Manitou Group
Sales manager for the UK & Ireland, BSL Battery
