Error code E-26
Does anybody know what E-26 means? Forklift is working properly. All functions are fully operational. It happened after seat with mini levers was disassembled. All wires are connected properly as before.
  • Posted 17 Feb 2015 07:17
  • By luke_com
  • joined 28 May'14 - 7 messages
  • Silesia, Poland
there is an error code list in the operation and maintenance manual of your truck, and on your truck, an e-26 refers to the heated oxygen sensor malfunction. what it means is the sensor is reading out of range some times, what makes an O2 sensor read out of range can very often be, and troubleshooting should start with, a good tune up. please only use O.E.M., not 'aftermarket will fit', spark plugs in these motors, as you may know the next person that has to remove the wrong plugs.
  • Posted 17 Feb 2015 10:29
  • Modified 18 Feb 2015 00:42 by poster
Toyota 8FG25
Enforcer FD50T-MMA
Toyota 8FG25
Enforcer FD50T-MMA
