Error Code C2-2
Anybody got any idea how to remedy this code? I know its a drive motor thermo sensor abnormality. The maintenance book tells me to use a special service tool to connect to a wiring harness. Not sure about the process. Any help would be greatly appreciated!!!
  • Posted 1 May 2020 00:53
  • By Duane_Carroll
  • joined 26 Mar'20 - 16 messages
Contact me in email.
  • Posted 26 Nov 2024 07:09
  • By John50
  • joined 7 Sep'19 - 155 messages
  • Netherlands
Hi guys,
I've got a similar issue C2-2 but also with error E2-2 which is saying both hydraulic and drive motor temperature sensors but I find that difficult to believe that both sensors would just fail at the same time
  • Posted 25 Nov 2024 18:22
  • Modified 25 Nov 2024 22:46 by administrator
  • By Forking_Around
  • joined 17 Jun'21 - 44 messages
  • New Zealand
Can you access the dasboard menu,s?
The European 7FB comes with a dasboard that is accessable to change settings, you can also access to test parts.
Underneath the plate with the gaspeddle you see the drivemotor, there are 2 connectors, 1 is for the drivesensor and the 1 with the 2 wires is for the temp. sensor.
You can check the resistance there and compare with the one from the hydr. pumpmotor.
  • Posted 18 May 2020 05:27
  • By John50
  • Netherlands
According to the maintenance book i have to disassemble the mast, pull the differential and the drive motor..... and tear the motor apart just to test the thermo sensor. What do you mean test it in analyzer mode?? What is I/O MONITOR 1/014, TD????
  • Posted 16 May 2020 06:00
  • By Duane_Carroll
You can check the sensor in Analyzer mode=I/O MONITOR 1/014,TD Temperature check
My quess is that the cpu board is defect, the temp. sensor hardly faills.
If you have a spare 7FB with same board i would change them.
You can check the temp.sensor with Ohm meter and compare with the hydr.pumpmotor sensor, they are the same.
  • Posted 3 May 2020 19:12
  • Modified 3 May 2020 19:14 by poster
  • By John50
  • Netherlands
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
UN Forklift FB25N1QZ1
Hangcha CBD15
China
USD1,600
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
