error code 80 /EP20KT
Hello ,
Please give the details of error code 80 for the CATERPILLAR ,EP20KT,ETB5A-76600
  • Posted 25 Apr 2013 18:24
  • By lishoy_t
  • joined 29 Oct'12 - 70 messages
  • dubai, United Arab Emirates
lishoythomas619@gmail.com
My info show error 80 as steer sensor error and Lo as battery voltage too low. you may have changed the voltage when you altered the D S R switch. Check your mail it should help.
  • Posted 26 Apr 2013 04:21
  • By controlelectric
  • joined 8 Dec'08 - 70 messages
  • Shropshire, United Kingdom
Hello , The error Code 80 is vanished ,when I had adjusted the DSW setting. Now the Display Shows " Lo". Battery seems to be good.
regards
Lishoy
  • Posted 26 Apr 2013 00:38
  • By lishoy_t
Hi lishboy,
I don't think there is a code 80 listed for this truck but a code 79 is relating to battery voltage to high, this would prevent line contractors from operating, if there is a code 80 I'm sure some one on this forum will let you know.
Regards Titus
  • Posted 25 Apr 2013 20:24
  • By Titus
  • joined 6 Jul'10 - 185 messages
Muncie, IN, United States
