Crown RMD6025-32:
Error Code 743
The Driver says this code comes up intermittently. Says display shows load 20 inches off floor when actually resting on floor.
  • Posted 24 Jun 2015 08:41
  • Discussion started by twoeey
Thanks southern Viking much help. Yea when I turned on 7 in features menu rest of menu's became accessible. Found counter wheel on left side of mast. Not riding on geared part of mast was sticking up. Being it is spring loaded. Cleaned mechanism reset it seems to have cleared up issue.
  • Posted 3 Jul 2015 05:54
  • Reply by twoeey
Access 7 operates auxiliary functions, ecr5 is the primary height encoder, L/H side of carriage bottom, needs to b turned on/off in features menu if you have it fitted.
If you have an access 7 R/H side of carriage you will only see these menus if access 7 is enabled, I've replaced a faulty access 7 and the replacement 1 failed as well, so got another then had to sync with software, then check features etc.
  • Posted 26 Jun 2015 12:38
  • Reply by southernviking
  • South Island, New Zealand
went to manual It tells me to reference error code 741. Then it says to access analyzer menu A2.7.4 run test for Fls switch. That tests fine it then says to. Step 2 Access A2.7.5 which is not in my menu also 3rd step Access point is also not there. A2.3.7 any ideas. As where too or how to access these points?
  • Posted 25 Jun 2015 09:06
  • Modified 25 Jun 2015 09:07 by poster
  • Reply by twoeey
edition #1228 - 1 May 2025
Linda Häkkilä Linda Häkkilä
Aichi RX07B
Nichiyu FB28PN77B367RRC
Lift Tek Elecar
