Error Code 743
The Driver says this code comes up intermittently. Says display shows load 20 inches off floor when actually resting on floor.
  • Posted 24 Jun 2015 08:41
  • By twoeey
  • joined 15 May'15 - 49 messages
Thanks southern Viking much help. Yea when I turned on 7 in features menu rest of menu's became accessible. Found counter wheel on left side of mast. Not riding on geared part of mast was sticking up. Being it is spring loaded. Cleaned mechanism reset it seems to have cleared up issue.
  • Posted 3 Jul 2015 05:54
  • By twoeey
Access 7 operates auxiliary functions, ecr5 is the primary height encoder, L/H side of carriage bottom, needs to b turned on/off in features menu if you have it fitted.
If you have an access 7 R/H side of carriage you will only see these menus if access 7 is enabled, I've replaced a faulty access 7 and the replacement 1 failed as well, so got another then had to sync with software, then check features etc.
  • Posted 26 Jun 2015 12:38
  • By southernviking
  • joined 25 Mar'13 - 43 messages
  • South Island, New Zealand
went to manual It tells me to reference error code 741. Then it says to access analyzer menu A2.7.4 run test for Fls switch. That tests fine it then says to. Step 2 Access A2.7.5 which is not in my menu also 3rd step Access point is also not there. A2.3.7 any ideas. As where too or how to access these points?
  • Posted 25 Jun 2015 09:06
  • Modified 25 Jun 2015 09:07 by poster
  • By twoeey
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
September 8-9, 2026 - Barcelona, Spain
November 11-12, 2026 - London, United Kingdom
February 8-10, 2027 - Mumbai, India
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
UN Forklift FD25T-C2JM1
Toyota 02-2TD20
