Error code 223 on right door
Hi all!
I have a crown wave60 that when I open the right gate travel door the wave beep telling me code 223. I have to close back the door and all is good. If I open only the left door it doesn't beep or tell me code 223 its just for the right door. Its not a big deal because we are now used to the wave beeping each time we open the door but if we can fix this that would make us be able to drive the wave with the doors open to go faster. Anyone knows what it could be and how to fix this?
Thanks in advance! :)
  • Posted 23 Jan 2024 11:15
  • By Djaztek
  • joined 23 Jan'24 - 84 messages
  • Quebec, Canada
I'll check that thanks :)
  • Posted 27 Jan 2024 02:57
  • By Djaztek
  • Quebec, Canada
Gate switches are on the side of the floor. There should be some plastic pieces on the rear side of the wave. Follow the gate arm to the bottom. Remove them to expose the cam and switches.
  • Posted 27 Jan 2024 02:21
  • By marcos_m
  • joined 25 Feb'19 - 114 messages
Ok thx. I was out for holidays... I'm now here going to check
Edit : after having removing the floor mat and sliding the metal floor base trap I don't seems to find the gate switch. I can't remove all the metal floor trap because the pedal are linked to it and don't wanna risk doing anymore lol :(
  • Posted 26 Jan 2024 23:00
  • Modified 15 Feb 2024 12:30 by administrator
  • By Djaztek
  • Quebec, Canada
Sounds like the cam/switches are getting worst. Have you gotten to that yet. That's the first step
  • Posted 26 Jan 2024 22:26
  • By marcos_m
Since yesterday there is a new weird behaviour with the wave60 maybe it can help for diagnosis? From now until yesterday the error code 223 was only popping when I opened the right side door. But now from time to time the wave won't start and the error code 223 is happening right when I turn it on and with the 2 doors closed. I have to open/close the door a few times or even restart the wave 2-3 times for it to be ok.
Also, sometimes when we drive it, it just stop moving right here and code 223 start beeping. I have to again open-close the door 2-3 times
And ita back again working....
Maybe this can help with the issue...
  • Posted 26 Jan 2024 21:22
  • By Djaztek
  • Quebec, Canada
Ok thanks
  • Posted 26 Jan 2024 20:38
  • By Djaztek
  • Quebec, Canada
I would check the gate switches and cam first. Always start with the basic
  • Posted 26 Jan 2024 12:42
  • By marcos_m
Ok thanks. I heard that it may be the access 2/3 that need to be replaced. Is it possible? I hope not cause its very expansive lol
  • Posted 26 Jan 2024 04:13
  • By Djaztek
  • Quebec, Canada
Check to see if the cam is damaged. If so, that will need to be replaced. Hopefully, the gate switches are just out of adjustment. Depending on your confort level, you can either replace it or call a tech. If you need to replace any parts, you'll need to call a forklift supplier to get them
  • Posted 26 Jan 2024 04:09
  • By marcos_m
And then when i'll be here whats the thing I should do? Is this something I can fix or I have to call a crown technician to come and repair?
  • Posted 25 Jan 2024 14:30
  • By Djaztek
  • Quebec, Canada
Thanks i'll check what I can do :)
  • Posted 25 Jan 2024 03:55
  • By Djaztek
  • Quebec, Canada
Yes, you need to remove the floorboard and lower covers to get to switches and actuator cam assy. Need allen wrench. A bit of a pain, but with patience, you'll get there
  • Posted 25 Jan 2024 03:33
  • By marcos_m
Do you know exactly where to check for the gate switch? Do I have to remove any thing for this?
  • Posted 25 Jan 2024 02:56
  • By Djaztek
  • Quebec, Canada
look at the gate switches on the doors you may find the roller cam is bent over
  • Posted 24 Jan 2024 19:09
  • By skyreach
  • joined 2 Apr'22 - 40 messages
  • Victoria, Australia
reach for the sky
Columbia, SC, United States
Cleveland Ohio, United States
Wentzville, MO, United States
The dot-com bubble, a period of large and rapid investments in internet-based companies, peaked in 2000 and saw the Nasdaq Composite index rise by 579%. Then the bubble imploded. As the value of tech stocks plummeted, cash-strapped internet start-ups became worthless and collapsed.
