Error Code 190-2
Dear Friend
Can You Help For This Code 190-2
  • Posted 13 Apr 2016 16:53
  • By KASBATIOUN
  • joined 3 Jun'15 - 12 messages
  • lagos, Nigeria
Thank You Brewski
I appreciated
  • Posted 20 Apr 2016 16:07
  • By KASBATIOUN
  • lagos, Nigeria
Code 190-2 is a crank signal loss code. It does not have anything to do with the transmission. You may have a VSM problem with this truck. I would check the directional solenoids and see if you have anything going to the coils. If not I would check the wiring from the ECU to the VSM for the crank sensor and cam sensor. You may have wires shorted in the harness.
  • Posted 15 Apr 2016 22:56
  • By BREWSKI
yes
Only Failure Forward & Reverse
  • Posted 15 Apr 2016 16:49
  • By KASBATIOUN
  • lagos, Nigeria
Will the engine throttle up?
  • Posted 15 Apr 2016 02:43
  • By BREWSKI
Machine Failure To Forward & Reverse
Stay in Neutral
Thank You
  • Posted 14 Apr 2016 23:06
  • By KASBATIOUN
  • lagos, Nigeria
Depending on the truck specs. This code is loss of crank sensor.
  • Posted 13 Apr 2016 22:29
  • By BREWSKI
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Hangcha CPYD25XH21JC
Flesherton, Ontario, Canada
edition #1237 - 3 July 2025
The use of "hello" as a telephone greeting is attributed to Thomas Edison. He is said to have suggested it as a simpler alternative to other greetings, such as "Do I get you?" or "Are you there?".
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
Zhejiang UN Forklift Co., Ltd
