BT Prime-mover RR B2:
Error code 153
Hi
we have a BT RR B2 reach truck s/n 731823 that intermittently comes up with error code 153
We found if you turned the hydraulic motor by hand slightly the error went away, so suspected the encoder bearing in the hydraulic motor and changed it, it seems that that has not cured it
Any pointers to what it may be?
Many thanks
PS changed a encoder on a yale pallet truck recently using one from TVH and it turned out to be bad, could it be a bad one again?
  • Posted 2 Jul 2020 00:14
  • Discussion started by P_E_G
  • Kent, United Kingdom
paul(at)gandgforklifts(dot)co(dot)uk
Hi,
Program the value of 17 to "0" in parameter and check.. is the same problem repeating.
inforklogisticssolutions@gmail.com
Hi,
Program the value of 17 in parameter, is the same problem repeating.
Board for pump (a2 board) problem from soket
Ameer
Manitou MH25-4
Ncn 85TH
Ncn 85TH 2014
Lift Technologies Inc.
edition #1234 - 12 June 2025
