error code 11
Dear Sir,
Kindly note that I have a Caterpillar forklift model EC25K that display error 11, I highly appreciate your help in solving this problem knowing that the controller is GE brand part No. IC3645SR4W606MC2.
Thank you
Ahmad Hadrab
  • Posted 21 Dec 2023 08:02
  • By Ahmad_Hadrab
  • joined 16 Dec'23 - 1 message
  • Jordan
Ahmad Hadrab
Electronics Maintenance Eng.
Tel:00962797455088
error 11 has to do with the start circuit, the accelerator switch
if the switch is closed on startup it will code out this code.
i would check and make sure it is returning to neutral and the start switch is opening when the pedal is released.
troubleshooting says to check P1-3 (wire 15) and make sure it is not shorted to positive.
it also says to check for a defective card, check P1-3 to negative. disconnect the wire and check P1-3 to negative, it should read zero volts, if not replace card.
  • Posted 23 Dec 2023 12:23
US forklift tariffs now 15% Washington, DC, United States
Crown names top North American dealers New Bremen, OH, United States
Stu Jacover Stu Jacover
Chief executive officer, TVH
