Error code 10
I have a cat EP16kt. This thing is making me lose my mind. It has an error 10 code and locks out the whole lift. If I try to cheat the system and cheat the self check by messing with the shift lever and gas pedal as soon as I turn it on, can drive it, lift, do anything. As soon as I fully let off the gas, the error code pops up and the whole lift sits dead in its tracks. I have swapped the motors to see if the code changes, the previous owner said he had the board changed, I have cleaned connections, changed accelerator sensor, and done all else I can think of. No matter what I have a code ten. This drives me nuts because it works so well normally. Please help!!!!!! Can I bypass this or something. I don't care, I just want it to work lol
  • Posted 30 Jul 2019 09:17
  • Discussion started by Ih8forklifts
I hate forklifts
code 10
Right Motor, Faulty Armature Circuit
Possible causes:
-faulty right motor armature
-faulty line contactor*
-faulty regeneration contactor
-faulty D1R diode
-faulty D2 diode
-faulty right motor armature wiring
-faulty head capacitor
-faulty T1R IGBT
-faulty CS1 current sensor
-faulty wiring in other parts
-faulty logic card
-faulty drive board*
-faulty H bridge board*
The * indicates the most likely suspects but you have quite a few things to check but check those first.
visually inspect the H bridge board and drive board underneath the logic card, look for any burnt diodes.
  • Posted 30 Jul 2019 12:42
  • Reply by swoop223
If this forklift uses an Accelerator Switch along with an Encoder or Potentiometer, there is a chance that the switch is out of sync.
The switch might be opening too early or too late.
It also might be closing too early or closing too late.
  • Posted 30 Jul 2019 12:40
  • Reply by LaGrange
  • Missouri, United States
Strong in mind, Strong in Health.
I'm not familiar with that model of forklift.
You might have a weak battery due to not be charged often enough or having its charge cycle interrupted.
The battery might need water.
You might need to recalibrate the Accelerator Potentiometer and Lift/Lower Potentiometer.
You'll need to be sure that Neutral is properly calibrated, for any of the Potentiometers on this forklift.
Most of the time, a numerically low Error Code typically means that a small problem is the root cause of the problem.
  • Posted 30 Jul 2019 12:37
  • Reply by LaGrange
edition #1235 - 19 June 2025
SMV (Konecranes) 4535TB5
Mitsubishi FGE35AT
ROYPOW
