Error C146 C016 and E068
Hi, I have this truck with these errors coming up intermittently and the operator says if he switches off and on, they clear and he can continue to use the truck.
I have no information on these trucks and not seen the code when I have tested the truck.
Any ideas?.
Thanks,
Steve.
  • Posted 15 Oct 2013 04:45
  • By steven_w
  • joined 20 Oct'06 - 16 messages
  • Aberdeenshire, United Kingdom
Dear Sir,
I have a Jungheinrich TFG 340S. It shows err 01 146. Please help me with a fix ASAP.
Thanking You,
Atharva
  • Posted 19 Nov 2016 15:19
  • By atharva_r
  • joined 19 Nov'16 - 1 message
  • Maharashtra, India
Atharva Rane
Error 68 refers to the safety switch. Check the wiring and switch.
C016 refers to drive disabled, controller MP1510C
C0148 reverse pedal, switch error, zero position switch does not match signal reading. Check for broken or short circuit in signal line. Some of these error codes are almost useless when fault finding.
If you get a chance to view the fault as it happens, look at the traction controller, there should be a 7 segment display. Make a note of which segments are lit. You can contact me direct by email, see my profile
  • Posted 15 Oct 2013 05:58
  • By Roibeard
  • joined 2 Mar'10 - 335 messages
  • Dublin, Ireland
