Error 58
Hi
Been out to the above truck comes up error 058 STEER ANGLE
The motor turns slowly when you power on the truck, would it be the sensor bearing or there is another sensor mounted on top of the motor under a cover
Many thanks for any suggestions
Paul
  • Posted 10 Jul 2020 00:55
  • By P_E_G
  • joined 30 Jan'13 - 78 messages
  • Kent, United Kingdom
paul(at)gandgforklifts(dot)co(dot)uk
Hi,
The Error code No = 58 is often caused by various causes such as the faulty of the bearing sensor inside the steering motor or the rim bearing above the gearbox/underneath of the drive motor was worn out leading to block the steering motor force.
I have recently faced with 2 trucks and each caused by one of the causes mentioned above.
  • Posted 26 Jul 2021 02:55
  • By Nunanemo
  • joined 24 Mar'19 - 24 messages
  • Viet Nam
Cheers
Nuna - Ho Chi Minh City
Email: dairongservice1973@gmail.com
Website: xenangdairong.com
Ah ok. Thanks for getting back to me.
  • Posted 24 Jul 2021 05:17
  • By Andrew
  • joined 30 Apr'21 - 3 messages
  • Ireland
Turned out to be the sensor bearing in the motor
  • Posted 24 Jul 2021 04:55
  • By P_E_G
Did you manage to find the fault? I have the exact same problem!
  • Posted 24 Jul 2021 01:49
  • By Andrew
  • Ireland
Hi. check the slewing bearing of the drive gear
  • Posted 29 Jul 2020 16:35
  • By Yevhen_K
  • joined 8 Jul'20 - 17 messages
  • kieskiy, Ukraine
Yevhen_Kiriienko
Maxlion MTF30-45-2WD
Aichi RX07B
