Clark CMP25L:
Erratic idling
I have a Clark lift truck CMP 25 LP that is giving me trouble it turns on but hads a erratic idle the RPMs go up and down i cleaned out the LP regulator cleaned out the carburetor checked all vacuum hoses seem to be OK is this carburetor electronic It has a Harness going to the bottom of the carburetor base Will I have to get a laptop connected to the truck I was thinking maybe is the LP pressure sensor any help To get me going to the right direction to fix this unit
  • Posted 6 Jun 2022 08:00
  • Modified 6 Jun 2022 08:02 by poster
  • Discussion started by Tony_Aguilar
Very nice !
  • Posted 7 Jun 2022 05:11
  • Reply by LaGrange
  • Missouri, United States
Strong in mind, Strong in Health.
Thank you that's what it was I replace the filter I need is up and running like a champ thanks again
  • Posted 7 Jun 2022 00:05
  • Reply by Tony_Aguilar
The symptom that you're describing is a clogged fuel filter.
If it has an IMPCO Lock off, you'll need to disassemble it and change the filter if it is dirty or deteriorated.
If the fuel system uses a fuel filter, it will most likely be attached to the propane hose near the radiator.
It's easy to find.
  • Posted 6 Jun 2022 22:00
  • Reply by LaGrange
Hitachi HX99B
Taylor TX330S
USD159,500
St. Louis, MO, United States
Johnston, IA, United States
Jefferson, WI, United States
