Erratic, high RPM and forklift shuts down
We have a 2007 Toyota 7FGU25 forklift that is killing us. I will see if I can attach a video. But I can send it to you if you want me to. I just need your email address? But when it first starts up, it will go real high in the RPMs and then it'll come down at some point and sometimes it'll do that two or 34 times but then after a few minutes, it levels out. If you make the tilt go front or back or the side shift, either way, then it will cause the RPMs to go up and even kill the engine. But on the mat up and down Leaver, it's fine. We have checked the wiring as well as the potentiometer on the little board on the side of the forklift. We've also tried a new TPS as well as throttlebody assembly. We've also even replaced the regulator with no effect. We're gonna try to clean the connector on the ECU today and see if that helps. we've never seen this kind of problem. Any help would be much appreciated. Thanks, Daniel. [email address removed]
  • Posted 16 May 2025 04:28
  • By DanielG
  • joined 21 Apr'17 - 5 messages
  • New Mexico, United States
DNS
For inquiring mind. What we found was a refining of 4 different things to alleviate the aforementioned problem in the previous post. We had to adjust the regulator mixture along with the potentiometer on the side of the forklift that is between zero and 5 V and also the Allen screw adjustment on the gas pedal. And finally, the timing. Between the 4 of those we finally got the right combination to Make it run normal. I appreciate the one and only response from the kind hearted technician who recommended checking the wires in the loom. Thank you for that. Daniel.
  • Posted 19 May 2025 09:21
  • By DanielG
DNS
  • Posted 19 May 2025 09:20
  • By DanielG
DNS
We will try that later today. Thank you so much. I hope that works. We just got back from servicing to Forklifts and we haven't even had a chance to pull the connector off of the ECU to clean it and check it. Make sure there's no corrosion or bad connections. I'll keep you posted. Thanks again. Daniel.
  • Posted 16 May 2025 05:38
  • By DanielG
DNS
Look at wire loom that is routed on the engine. Wires break inside this loom.
  • Posted 16 May 2025 05:04
  • By Mechabob
  • joined 11 Jun'20 - 5 messages
  • Washington, United States
Taylor T520S
UN Forklift FD35T-C2JB2
Giant dragonfly-like insects existed before dinosaurs and were known as "griffinflies". They lived around 317-247 million years ago and had wingspans of up to 71 cm (28 in).
Taylor T520S
May 14, 2026 - Blair Athol, South Australia, Australia
Jason Morgan Jason Morgan
director of aftermarket, Noblelift North America
sales manager of Texas, Taylor Machine Works
board advisor, Humanitarian Logistics Association
lead sales - Northern Europe, Camso Construction
