Cat Lift Trucks (& Caterpillar) EP20K:
EP20kc error code 30
Hello, I have a problem with a cat ep20kc serial number ETB7A-005XX, it shows error code 30 when it is running for around 1 hour (when it goes hot), anybody knows what this code means? I tried with the little logic card in the right side (the one with a conector in the left side and other connector in the down side), tried also the traction transistors, and the pump transistor with no good results... Any help will be so much appreciatted.
  • Posted 10 Aug 2014 21:46
  • Discussion started by jose_p
  • Kentucky, United States
code 30 is a pump motor fault
possible causes:
- Faulty pump motor circuit
- faulty line contactor
- faulty diode
- faulty pump motor wiring
- faulty head capacitor
- faulty T1P IGBT
- faulty current sensor CS
- faulty wiring in other parts
- faulty drive board
these are all the components that can effect this code.
you have already ruled out some of them , check the others listed here.
  • Posted 1 Sep 2014 01:51
  • Reply by swoop223
Hangcha CBD15
China
USD1,600
Terberg BC182
edition #1228 - 1 May 2025
Yale Lift Truck Technologies
Kalmar DCG16-900
TCM FD115-3
Linda Häkkilä Linda Häkkilä
