Engine Removal bolt access
I'm removing the 3.0 from my 1990 Hyster 50 I'm removing the bellhousing cover bolts I'm having trouble with a bolt that is next to the hydraulic hose from the pump no way to get a wrench or ratchet do I need to remove the pump and if so is it difficult Thank You for your time.
  • Posted 2 Jun 2024 21:43
  • By dmarr35
  • joined 25 Dec'23 - 3 messages
  • Illinois, United States
Dmarr35
Thank You I will Try
  • Posted 3 Jun 2024 20:42
  • By dmarr35
Dmarr35
If it the bolt at the pump the only way to get it out is with a 9/16 wobble head socket no wrench or regulator socket will work. Good luck
  • Posted 3 Jun 2024 09:50
  • By Scott_
Scott
SMV (Konecranes) 4545CCX5
Manitou MH25-4
