Engine Dies when lifting
I have a 1987 Yale GLP060RCJUAE086. When Lifting , the engine wants to die. Even if I throttle it up when lifting. Any help would be greatly appreciated. Thanks.
  • Posted 5 Dec 2020 01:39
  • By Ed_Corsaro
  • joined 5 Dec'20 - 4 messages
that lift have an idle up dashpot on it?
generally when you load up the engine the dashpot will use the vacuum change and trigger the dashpot to push the throttle just a bit to keep it in a good power range so it won't stall out under a load from steering or hydraulic operation.
  • Posted 21 Dec 2020 04:17
Some times the valves get a lot of build up in the intake side and this may be what is causing poor power
  • Posted 16 Dec 2020 03:05
  • By stillworkin
  • joined 2 Nov'18 - 96 messages
Compression is very good..High 155 and low i 150
  • Posted 16 Dec 2020 01:08
  • By Ed_Corsaro
do a compression check should answer all your questions or at least give you a better place to start
  • Posted 11 Dec 2020 01:54
  • By stillworkin
It drives fine. When lifting it puts "strain" on the engine....pump dead heading?
  • Posted 10 Dec 2020 01:06
  • By Ed_Corsaro
What happens when you turn the steering? Also what happens if you turn the steering completely to the right or left and hold it against the stop then try to lift?
  • Posted 5 Dec 2020 06:38
  • By lifterfixer
  • joined 15 Jun'17 - 6 messages
It's like there is too much load on the engine. It drives fine unloaded.
  • Posted 5 Dec 2020 06:13
  • By Ed_Corsaro
Hi Ed, you say it wants to die? Is it running out of power type of die, or is it just shutting off like you are turning the key off? Does it have plenty of driving power?
  • Posted 5 Dec 2020 05:07
  • By lifterfixer
Héctor Guerrero Castañeda Héctor Guerrero Castañeda
Managing director, Jofson
CEO, Robust.AI
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
