engine cranks no power to coil
Ser#b875b03690d 2.4 gm lpg. Engine cranks no start. No power to ignition coil. New cam and crank sensor. Sent engine ecm out for testing came back with every thing good.engine has oil pressure 30 psi. On the left side of engine and transmission in the engine compartment there is a 5 prong wire connector that nothing plugged into it. It looks like there was a relay plugged into it. Harness has a tag on it #cps 206 any help is appreciated thanks
  • Posted 19 Mar 2025 01:27
  • Modified 19 Mar 2025 05:48 by administrator
  • By jerryb
  • joined 23 Jul'14 - 7 messages
  • New Mexico, United States
jerry berg
Jerry,
CPS 206 is for a relay. Install relay into connector and see if truck starts. This supplies power to the ECU which send it throughout the engine. If you install relay and engine does not start, check fuse 6 inside the PDM. Should be a 20 amp fuse. Good Luck.
  • Posted 25 Mar 2025 00:57
  • By Fishmech
  • Virginia, United States
Hangcha CBD15
China
USD1,600
UN Forklift FB25N1QZ1
September 8-9, 2026 - Barcelona, Spain
November 11-12, 2026 - London, United Kingdom
February 8-10, 2027 - Mumbai, India
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
RAEDER-VOGEL
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
