engine codes
have engine codes 106.4 and 52265.5-0 coming up engine ran but hesitated when revved up, found diaphram in carb faulty-installed new diaphram runs ok but when throttle held will start to lean out and lose power,has full fuel tank,unplug map sensor and runs fine, any help would be great
  • Posted 22 May 2013 05:29
  • By oldywan
  • joined 20 Jan'13 - 21 messages
  • Saskatchewan, Canada
If its broke it can be fixed
thanks for the info- problem was in the computer controlled regulator- the evaporator was partially plugged and the diaphragms and valve were also dirty-cleaned out and replaced bad parts runs like a dream now
  • Posted 9 Jun 2013 10:24
  • By oldywan
106-4, indicates map sensor fault.
However the following can also cause map sensor issues.
522655-0 PROCEDURE OR ACTION:
1. Common problems that may cause rich codes:
* Clogged/dirty air filter
* Fuel quality (Very high butane content)
* Operation at high altitudes
* High primary fuel pressure (for trim fuel injector)
* Faulty trim fuel injector or wiring
* Faulty LPG carburetor (power valve stuck open)
* Faulty LPG regulator
* Manifold vacuum leaks
* Improper ECU grounds on engine block
* Faulty ECU injector driver 2
2. If DTC continues to be displayed after examining/correcting the above
  • Posted 7 Jun 2013 11:17
  • By meliftman
  • joined 31 Jan'12 - 209 messages
  • Alabama, United States
Liftman
Retired
Elberta, Al.
the 52265.5-0 is not correct 522655-0 for vortec v6 ???
  • Posted 27 May 2013 06:25
  • By AAPEE
  • joined 28 Aug'12 - 76 messages
  • Brussels, Belgium
Sue Tomic Sue Tomic
UN Forklift FD35T-C2JB2
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Sue Tomic Sue Tomic
USD1
