Engine check light.
Hi all, I have a Toyota 7FGCU45 with the GM v6 Vortex engine. The engine check light in the right hand corner of the display is lit with no problems with the truck operation? when the ignition is on and engine not started it blinks slowly the code 1. any ideas what will cause this fault code. Thanks for your help.
  • Posted 9 Oct 2014 02:23
  • By GSXGSX
  • joined 9 Oct'14 - 4 messages
  • Lancashire, United Kingdom
Hi LTS1 do you know what blink code 1 means?
  • Posted 18 Jun 2020 20:06
  • By GSXGSX
If you are looking at the pins inside the connector, with the connector clip to the top... It will be the top row of pins, far left is Pin 1, far right is Pin 4
  • Posted 26 Jul 2016 10:10
  • By LTS1
  • joined 18 Dec'13 - 74 messages
What pin is 1 and which is 4....?
  • Posted 26 Jul 2016 00:57
  • By racinjunkii
  • joined 11 Jun'14 - 15 messages
You will need to jump pin 1 and 4 on the diagnostic connector to enter blink mode. Then with key on and engine off the check engine light will blink the code. Most likely the O2 Sensor is faulty or fuel is rich or lean. Most of the time this is the issue with these trucks.
  • Posted 20 Oct 2014 06:26
  • By LTS1
Taylor THC500L
Mitsubishi FGE35AT
