Electric Stacker not charging
Was hoping to get some help on what I hope is an easy fix. Got this stacker about 2 weeks ago and ran and charged great. We used it yesterday and tried charging it and it suddenly wont charge. It just plugs in to a normal outlet and from what I've read the red light is supposed to blink, indicating its charging. Now when plugged in the red light stays solid and we cant get it to charge at all. Was working just fine prior to battery getting drained with use. Any ideas? Any help would be much appreciated.
  • Posted 3 Oct 2020 07:07
  • By Justin
  • joined 3 Oct'20 - 1 message
  • Utah, United States
Justin Banner
CEO, VERVE
Sounds like the battery is still flat. Can you measure the voltage of the battery.
Have you checked the water level of the battery ( if its a lead acid battery ).
Water level should only be just above the plate level. no higher
  • Posted 5 Jun 2024 00:10
  • By Paddyteclinde
  • joined 3 Dec'21 - 33 messages
  • Ireland
Was able to hook it to a charge and get the internal charger to kick on. I let it charge all night but when I turn it to the on position the charge level indicator blinks back an forth on the two lowest bars. Not sure what thats about
  • Posted 4 Jun 2024 23:41
  • By Brady_Becker
  • joined 4 Jun'24 - 3 messages
  • Colorado, United States
Brady
When the charger is connected to the battery.The battery charger needs a voltage back to operate a relay to start the charge process.If the battery voltage is too low , the voltage back is too low to bring in the relay.
If the battery is a standard 24 volt just use a standard car/lorry 24 volt charger to bring the voltage up.15 minutes should do.Then reconnect its own battery charger and it should be ok
  • Posted 4 Jun 2024 20:32
  • By Paddyteclinde
  • Ireland
I just ran into a similar issue. Left ours on all night by accident and now when we try to charge it just shows the yellow fault light. Is there a fix for this?
  • Posted 4 Jun 2024 06:28
  • By Brady_Becker
Brady
Sounds like battery voltage may have drained low enough to not kick charger on. Do you know what the static voltage is?
  • Posted 27 Oct 2020 02:15
  • By Triggs
Aichi SR10C1SM
Taylor TT300
USD98,500
edition #1302 - 8 October 2026
In this week’s Forkliftaction News , we have two stories reminding us of the power of a generous spirit... Continue reading
Tapio Rummukainen Tapio Rummukainen
President, Logisnext Europe
Chief operating officer, Clark Material Handling Company
Lithium battery sales manager, BSL Battery
Chief executive officer, Corvus Robotics
March 16-18, 2027 - Stuttgart, Germany
October 26-27, 2026 - Fort Shelby, Michigan, United States
