Easy ev100 question
I had an error code that showed possible problem w/ a shorted #23 rec (snubber #3). Its easy enough to find the problem snubber, but how do you count ( the problem was not the snubber, but the #3 rec), from the top down or the bottem up? There are 4 snubbers.
  • Posted 19 Aug 2012 01:45
  • By 7777
Thank you JP
  • Posted 20 Aug 2012 07:03
  • By 7777
yes, if you look at it horizontal with cap on left they lay out as so:
23rec (filter) closest to capacitor far left
24rec(filter) next to it center left
25rec(filter) next to it center right
22rec(filter) closest to #2 and #5 recs , far right
the #3 rec (flyback diode) is mounted directly underneath the capacitor
the #4 rec (plugging diode) is mounted directly underneath the #1 rec (the big square block the filters and spider block are mounted on top of).
pretty much ANY information you will ever need on these systems from GE can be found here:
ht tp://w ww.fsip.biz/GEManualsDownload.html
just fix the url so it will work, remove the spaces i added so the forum filter wouldnt zap it out :o)
create a folder on your harddrive and label it GE manuals and download each of these you need and store it there for quicker reference later on, i did... keeps you from having to redownload them everytime you need information
  • Posted 19 Aug 2012 23:24
  • Modified 19 Aug 2012 23:28 by poster
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
thank you
  • Posted 19 Aug 2012 19:44
  • By 7777
Should have a blue wire on one side(side closest to card) and a brown wire on the other(side closest to #3 rec)
  • Posted 19 Aug 2012 02:01
  • By kevin_t
#23 will be the one closeset to the capacitor,the very top snubber
  • Posted 19 Aug 2012 01:58
  • By kevin_t
Deborah Baker Deborah Baker
