E60XM2-33 TRACTION MODULE BURNT UP NO STEER MOTOR NOW
I have a Hyster E60xm2-33 and the traction control module burnt up. I replaced it and put the lap top on it to input my old traction hours. My steer motor will not turn on now. The only way to get it to work is running a jumper from the ground to the negative side of the steer motor coil. Then everything works like it should.
What did I miss or do wrong? Any help would be appreciated?
Thanks NITETIME
  • Posted 2 Jun 2016 20:41
  • By nitetime
  • joined 6 Feb'14 - 17 messages
  • Michigan, United States
Ncn 110TH
Ncn 110TH 2015
Manitou MH25-4
Ncn 110TH
Ncn 110TH 2015
Manitou MH25-4
