E20P-02 doesn't lift
Hello,
tomorrow I'm going to see a faulty E20P-02.
The forklift drives but the forks don't work.
I never worked on Linde and I don't have any docs for this machine.
Are there any known issues?
Is there any outside factors that can cut off joystick or hydraulics?
  • Posted 19 Aug 2014 22:53
  • By ivanlinaric
  • joined 16 Jan'11 - 110 messages
  • Zagreb, Croatia
Service technician.
Feel free to contact me at ivan.linaric@okretnimoment.hr
Hi i know i am like 10 years late on this but did you ever figure out what the cause was on your Linde?
I have one that is doing precisely the same thing, also checked all the stuff as per your posts, hydraulics work with steering but lifting/tilting/side shift not working or engaging hydraulic pump. changed the joystics and still the same.
Had a guy come out to diagnose it and all that he said the valve DAB9 is faulty, tested all the valves and working 100%.
Please any help will be appriciated.
  • Posted 25 Sep 2025 20:18
  • By Randelph_Kruger
  • joined 25 Sep'25 - 1 message
  • Gauteng, South Africa
Randelph Kruger
Well,
it was the sideshift joystick.
Since I don't have any diagnostic tool I used description of faults.
I have checked all inputs were a fault turns off the hydraulics.
The sideshift joystick was a little off with his voltage when in neutral upon key on. I have turned the potentiometer on his shaft until he was showing 7.1 V in neutral. After the next key on the hydraulics turned on.
Now, all hydraulics work except the sideshift which turns off when I push the joystick fully to the right. I've checked the voltage and it doesn't go out of range.
What do you think?
  • Posted 23 Aug 2014 03:10
  • By ivanlinaric
  • Zagreb, Croatia
Service technician.
Yes,
I tought a control module problem too, but I wanna be sure of course.
Also, it seems that the control module has already been fixed cause it has some unusual stickers on.
  • Posted 21 Aug 2014 00:34
  • By ivanlinaric
  • Zagreb, Croatia
Service technician.
Well - it looks like a control module problem.
Check your mail,
I send you catalogue page where you can identify the modules (you may have the version with two independent modules or one integrated, (pos. 28, 29 or 29a)
I send you also the description of the pins and signals on the independent lift module.
Use it for checking.
Good luck
  • Posted 21 Aug 2014 00:21
  • By Karait
  • joined 21 Jun'09 - 355 messages
  • Poland
I know your deepest secret fear...
J.M.
Hello,
I've just got back from the machine.
Here are the facts:
- lift/tilt/sideshift hydraulics do not work
- hyd. pump doesn't activate when moving the joysticks
- there's no power supply to "hydraulic enable" solenoid valve
- "hydraulic enable" solenoid valve coil OK
- joysticks input and output OK
- switching joysticks doesn't help
- steering OK (it activates the hydraulic pump)
- drive OK
- double module A1 OK (left motor and hyd. pump)
- power supply to main control unit A2 OK
- no warnings on the dashboard instrument
- hourmeter and battery discharge level meter OK
- battery voltage and all fusses OK
- voltage converter OK
- seat switch OK
- handbrake and service brake switch OK
- emergency isolator OK
What inputs must be present to make the hydraulics work?
  • Posted 20 Aug 2014 23:45
  • By ivanlinaric
  • Zagreb, Croatia
Service technician.
OK, thanks.
  • Posted 20 Aug 2014 02:00
  • By ivanlinaric
  • Zagreb, Croatia
As I've written - may be several issues - from the pump to the control module.
Is there no hydraulics at all?
Is there some additional hydraulics installed on the truck (sideshift)?
If yes - is it deactivated too?
If it works - this is probably a joystick issue.
So put the joystick from the extra hydraulics to the socket of main hydraulics. This will confirm the failure.
Is the motor pump working?
If no - probably you have issues with the hydraulics control module.
If yes - check the pump nad pressures before and after the control valve.
Of course - on the beginning, check the battery condition.
The truck may have the hydraulics "switch off" function, when the battery is too weak or discharged.
Unfortunately Linde developed this truck only to be diagnosed with diagnostic software.
  • Posted 20 Aug 2014 01:50
  • By Karait
  • Poland
J.M.
Any ideas beside joystick?
  • Posted 20 Aug 2014 01:23
  • By ivanlinaric
  • Zagreb, Croatia
Service technician.
It's 335.
I don't have any soft.
  • Posted 20 Aug 2014 01:17
  • By ivanlinaric
  • Zagreb, Croatia
Service technician.
May be a lot of issues.
What series is this 335 or 336?
Or perhaps 386?
Probably joystick problem.
Truck Doctor or Pathfinder (Linde softs) would be usefull.
  • Posted 20 Aug 2014 01:15
  • By Karait
  • Poland
J.M.
edition #1299 - 17 September 2026
With the world changing, in seemingly too many ways to fully comprehend, businesses need to be agile enough to change with it... Continue reading
The dot above a lowercase "i" or "j" is called a tittle.
