E150 code
This issue began with a bad ac controller. After replacing the controller the unit started throwing a e150 code for can wiring. I replaced both harnesses between the controller and the etac card, same issue. It will not take software and the download quits at randomly, sometimes it will make it to 90% before it stops. Any ideas?
  • Posted 15 Apr 2022 00:19
  • By Colt_Cole
  • joined 15 Apr'22 - 1 message
  • Arkansas, United States
Colt
As far as your software issue, disconnect the DeltaQ charger and then try loading the latest software. The charger causes some kind of run time problem when loading the traction amp.
  • Posted 18 May 2022 09:04
  • By ErichO
  • joined 26 Oct'21 - 83 messages
  • Washington, United States
Bolzoni SpA (Group HQ)
