E107 LPE200 /8
Hello, anyone can help me with the code E107?
I already checked the main contactor, 130 amp fuse and alot of things, without solution ;(
sorry for my bad english, i'm brazilian
  • Posted 28 Mar 2014 01:31
  • By gnomo_lodi
  • joined 28 Mar'14 - 1 message
  • Rio grande do sul, Brazil
What is the state of charge of the batteries? I have seen contactors test ok and install a new one and it worked fine.
  • Posted 31 Mar 2014 02:27
  • By rogeriwt
How did you check the main contactor? What fuse did you check and how? Use voltage drop test on fuse, never an ohmeter. Jumper it to test if your not sure. Contacts are sensitive. replace the points if not sure. They must be perfect or you get a code
  • Posted 28 Mar 2014 11:00
  • By EasiTek
