Drive Motor Bearings
It seems that I'm having to replace a disproportionate number of bearings in our trucks. It's always the drive-end bearing in the drive motors that go bad. Is anyone having similar problems and any ideas as to the cause?
  • Posted 4 Mar 2011 09:24
  • By jeff_i
  • joined 2 Nov'08 - 15 messages
  • Iowa, United States
Any luck with the bearing inspection or need to wait for a bearing to go bad?
  • Posted 9 Mar 2011 09:47
  • By fredz0003
  • joined 25 Feb'11 - 69 messages
Raymond Action
We have about 50 trucks and never changed a bearing on a drive motor, units are 3 years old.....any lucks on the inspection?
  • Posted 5 Mar 2011 12:21
  • By fredz0003
Hi Jeff can you describe appearance, wear, discoloration, surface distress or anything that you see wrong with the bearing, how many have you changed? The same truck or several trucks..There are several reasons why a bearing can go bad, but most important how old are your forklifts?
Does your unit has a gearbox.... Have you checked the fluid on it....this can create heat and heat can damaged bearings. ( just a thought)
I should add inspect damaged bearing with magnifier some damaged is not visible to the naked eye...perhaps cutting the bearing to inspect the inside of the bearing...there's always a clue...
As you can see I love finding solutions if you could take pictures and email them I will surely appreciate and perhaps I could investigate based on the pictures of the bearing my email is ic3balandran at yahoo dot com
Last edit I promise I have created face book pg to carry on discussion only for raymond trucks I think is a lot easier to share pics and links and so on look me up at Raymond Action on fb and pass the word plz.
Just a question how are you installing the bearings? I gotta ask...
  • Posted 4 Mar 2011 10:23
  • Modified 4 Mar 2011 23:31 by poster
  • By fredz0003
Raymond Action
F. Uchiyama
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
St. Louis, MO, United States
Evansville, IN, United States
Uxbridge, Canada
Daleville, IN, United States
GemOne
