DPF Regeneration engine CPYB - LINDE H35D-02
Hello everyone,
I have problem with LINDE H35D EVO with VW engine code CPYB.
The problem is I can't connect with the vw engine diagnostic tool to this type of engine to start a force dpf regeneration...I tried with all types VW CR; VW P-D; VW SDI;...but it is not founding the engine control module..
Is someone knows what can be done or what diagnostic tool I need?
I use diagnostic cable 3003652503
Here is the info for the forklift:
H35D-02
SN: H2X393D51030
YEAR: 2013
ENGINE: VW - CPYB
Many thanks in advance!
  • Posted 12 Feb 2022 02:17
  • By ivaylo_p
  • joined 20 Feb'16 - 9 messages
  • SOFIA, Bulgaria
with lsg I just use the diesel cable
  • Posted 22 Feb 2022 02:49
  • By michel_v
  • noord holland, Netherlands
ivaylo.petkov at stroyrent.bg
backshot63 at gmail.com
  • Posted 22 Feb 2022 01:44
  • Modified 22 Feb 2022 01:51 by poster
  • By ivaylo_p
  • SOFIA, Bulgaria
give your mail
  • Posted 22 Feb 2022 01:20
  • By tr_doctor
  • joined 4 Dec'20 - 186 messages
  • Netherlands
Regards
Is this LSG was only parts, service and procedure manuals software or I'm wrong?
Can you do a DPF Regeneration with it?
I have already Pathfinder with LINDE CANBOX, also the cable for VW engine diagnostic but we are unable to activete the DPF regeneration procedure with either...
I will be very grateful for some help to solve the situation!
Thanks in advance!
  • Posted 22 Feb 2022 00:45
  • By ivaylo_p
  • SOFIA, Bulgaria
you must use the linde canbox , not only a single cable,and pathfinder diagnostic software
  • Posted 21 Feb 2022 05:38
  • By tr_doctor
  • Netherlands
Regards
lsg is linde service gade
is only for linde montuers
  • Posted 21 Feb 2022 04:26
  • By michel_v
Thank you very much for the answer!
Would you tell me where can I find this LSG softwere ?
And is this LSG can activate DPF regeneration?
Thanks in advance!
  • Posted 21 Feb 2022 00:21
  • By ivaylo_p
  • SOFIA, Bulgaria
you have the right cable but i had the same problem with phatfinder but with lsg no problem
  • Posted 20 Feb 2022 20:24
  • By michel_v
