Doesn't Turn on.
I just got this forklift from auction. It's a 1998 Yale Electric. Battery from 2012. 48V. Used it for a few days, everything OK. Then did an equalize charge a couple days ago, everything OK again. Checked all the cells, all fall within 2.09-2.125V, Acid levels all good, if not a tad high, but I'm using a cheap hydrometer.
Used it today for about 10 minutes, turned it off and then a few minutes later turned in on and it beeped and did nothing. Turn it off and on again, nothing. Unplugged the battery and let it sit a minute. Turned it back on and the start up screen did it's startup procedure a few times then stopped working. I checked the voltage of the battery it was at 49V, I threw it on the charge just to be sure as I've never had an electric forklift before. It charged for about an hour then turned off. So I assume it was full.
Any help would be appreciated.
I guess first off are there an interlocks that I should check. I mean if you're not in the seat will the display still turn on? I assume it would. Also not sure where the fuses are.
  • Posted 15 May 2017 09:27
  • By carter_r
  • joined 15 May'17 - 6 messages
Cool. Thanks.
  • Posted 16 May 2017 10:28
  • By carter_r
It sounds like you have the performance display. I think the green button is for displaying stored fault codes. Your serial number is good, this truck shipped with a tall mast. Your mast should measure 140" lowered.
  • Posted 16 May 2017 05:37
  • By BREWSKI
I meant if it had the fourth valve option.
I Know the rest of it, but they put on a different Yale mast. It goes to 324". Goes super high.
Do you know what the green button on the dash does? The yellow sets the speed, but not sure what the green button does. When I press it, it does nothing. Actually I don't think I tried it since I fixed the issue. I'll go try it.
  • Posted 16 May 2017 04:24
  • By carter_r
Not sure what specs your talking about but i can tell you from the Model number that it is rated to pick up 5,000 pounds.....is a 48 volt battery in the truck.....is SCR controlled....has a triple stage mast with a height of 140 inches...and has solid cushion tires
  • Posted 16 May 2017 04:18
  • By kevin_t
Model ERC050ZFN48SE140, Serial E108V09508V
@ Kevin, that makes sense. Thanks. The reason I asked is because the LED for hour meter never worked before. Not sure why it's working now. I assume the positive wire that shorted the system blew the fuse; so not sure why the hour meter is now working as I only changed one fuse. Weird. Unless that crushed wire was shorting the system causing the hour meter to not function and it finally make enough current to blow the fuse.
Anyway, what about my model number and serial is there a way you can tell the specs of my machine? Believe it or not my local Yale dealer says they don't have any information on it or Yale. I found that hard to believe so I emailed Yale and they said to contact my local dealer. LOL
  • Posted 16 May 2017 03:18
  • By carter_r
Complete modle and serial number of truck??? The -02 means that the forward switch is closed when the key is turned on.....the ther two are probably the hour meter readings....the 4472 is for drive hrs and the 2710 is for lift hrs...l
  • Posted 15 May 2017 21:05
  • By kevin_t
Ok turns out an accessory that the last company installed; the wires were pinched on one of the cylinders and shorted out.
Changed the fuse and everything is OK.
I get beeps upon startup now and shut down. I think the startup beeps show -02 on the display. On shutdown I get 4472 and the hourglass and tire with motion lights go on, then I get 2710 and the hourglass and lift lights.
  • Posted 15 May 2017 13:29
  • By carter_r
After doing some digging I found the fuses. Figured it must get in a big area. For those that don't know the entire fuse and electronic section is in the back behind the panel that says Yale on the forklift weight.
So I did have a bad fuse. I pulled some dead wiring out the other day, stuff just wired for electricity for warehouse stuff. It worked after that so I'll check to see if I didn't hit something. Pretty sure I didn't I work with way more complicated electrical systems than this.
  • Posted 15 May 2017 11:10
  • By carter_r
UN Forklift FBR25NQC3
TCM FHD105Z
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Taylor TX330S
USD159,500
