Thanks edward_t so much, i understand your ideas, I send you file attached, can you tell me more detail about this
Please check your email.
my guess is this truck has an "SBX" type of battery connector, and your older battery has the SB connector.
The SBX connector in the truck is designed to have a connection that is a closed circuit between the small middle connectors that disconnects -before- the larger power cables loose connection. this is to prevent damaging power spikes when the larger power cables are disconnected or connected. At least that is how I see most of them used these days.
putting a jumper wire in the wire circuit for the middle connection may help get the truck running or for testing, but there is a VERY good reason for having that middle connection, and disabling it will eventually cause damage to the [high dollar] controller, that would otherwise never happen.
if this is the case, you will need to get a jumper set of connections to allow the SB connector on the battery connect to another SB connector, and have a properly wired SBX connector to connect to the truck, that will be the jumper that provides the completed circuit through the small SBX connection.
