Dash or Instrument Cluster
After a minute or two on normal operation the battery level indicator on the dash goes blank. The back light is still lit and the forklift still operates nomally. The dash will still show the blinking wrench but not trouble codes. I am trying to determine if it is the dash or something before it that has a problem.
  • Posted 25 Sep 2015 00:21
  • By cbarnes
  • joined 25 Sep'15 - 1 message
1st thing is to confirm you have a good battery, and the battery is not loosing voltage under load. read "at rest" voltage and hydraulic stall (not more than 3 seconds max lift height stall, should not drop more than10% of "at rest" voltage").
Next is to confirm no shorts to frame from ANY power cable of less than 100K ohms.
  • Posted 25 Sep 2015 10:04
  • Modified 25 Sep 2015 10:05 by poster
ROYPOW
