4G6 engine are the same. /OHC/
see link
mitsubishi-motors.kiev.ua/Manuals/Engine/pwee9616/11A.pdf
is the g424 engine fitted in this truck, BearsFan4Life?
When you say "the oil pump drive shaft seal", where are you expecting to find that seal? are you going to drop the pan to get to the oil pump drive shaft? The g424 has a oil pump drive off the timing belt, not off the valve's overhead cam.
Or are you talking about the hydraulic pump's drive shaft?
does anyone know if to replace the front main seal, Cam seal, Valve Shaft seal and Oil Pump drive shaft seal does the engine have to be fully removed from the forklift? it is a G30E S/n CX-05173
Leon, G424 is the Mitsi engine. The G430 is a GM 3.0 engine.
