Daewoo/Doosan Trouble codes
I have a customer who has a Daewoo G30E-3 with a serial number of FGA09-1790-03127. He has been having issues with the unit running rich and the MIL on the dash staying on. I know there is a pedal dance to access the codes but cant remember for certain what it is. Can anyone tell me the sequence and perhaps give me a list of the codes and what they mean?
Any help is much appreciated!
plt2help at gmail dot com
Thanks
Kevin
  • Posted 15 Jun 2017 07:38
  • Modified 13 Jul 2017 16:42 by administrator
  • By Gump
  • joined 10 Jun'11 - 30 messages
  • Iowa, United States
Yes,any good forklift tech will have info on all the diffrent sytems and trucks he comes in contact with...
.knowledge is power in this profession....retrn here with a code(s) that you retrieve and we will be able to help you out....
  • Posted 15 Jun 2017 11:11
  • By kevin_t
Thanks for the help Kevin! Do you by chance have a code description list?
  • Posted 15 Jun 2017 10:26
  • By Gump
To enter code display mode you must turn OFF the ignition key. Now turn ON the key but do not start the engine. As soon as you turn the key to the ON position you must cycle the foot pedal by depressing it to the floor and then fully releasing the pedal (pedal maneuver). You must fully cycle the foot pedal three (3) times within five (5) seconds to enable the display codes feature of the SECM. Simply turn the key OFF to exit display mode. The code list will continue to repeat until the key is turned OFF. An automatic code display feature is activated if a foot pedal fault condition exists. This feature enables the service technician to view the fault codes by turning the key to the ON position, if a foot pedal malfunction is preventing the retrieval of the stored fault codes from the SECM.
All MI-04 fault codes are two digit codes. When the fault codes are retrieved (displayed) the MIL will flash for each digit with a short pause (.5 seconds) between digits and a long pause (1.2 seconds) between fault codes. A code 12 is displayed at the beginning of the code list.
  • Posted 15 Jun 2017 09:34
  • By kevin_t
SMV (Konecranes) 4531CC5
UN Forklift FL20-32LNJX2
