crown sp3000 stockpicker error codes
Hi everyone, can anyone help me with crown sp3000 stockpicker error codes, ive got a unit the wont key on and spanner light comes on only being able to access error code 16 as last code shown, any help would be great thank you
  • Posted 24 Oct 2013 07:28
  • Discussion started by thetine_m
  • Victoria, Australia
Cheers Matty
This status code is displayed when the battery volts are greater than 2.40 volts
per cell at initial start up.
Symptom: Forward or reverse contactor will not energize.
Possible Cause
- Battery overcharged or incorrect battery installed.
* Check battery state-of-charge and take corrective action if necessary.
- Incorrect control card setting.
* If control card was just installed, make certain Function 15 of control card tune up is set correctly. Refer to tune up
section (M4.2 in truck Service Manual) for correct value.
  • Posted 20 Sep 2020 07:19
  • Reply by mike_v
  • Illinois, United States
mike_retired
Bom Dia
Teria o manual desse equipamento SP3000 ou poderia me passar o whatsapp para conversarmos.
Obrigado!
  • Posted 20 Sep 2020 01:38
  • Reply by Felipe
  • RS, Brazil
Estou com um equipamento da crown modelo SP 3000 está me dando o código 07.
208
This status code is displayed when the steering selftest shows no movement.
Enable Configuration: NNNY YYYY
Steering disabled
Full traction disabled
Limp traction disabled
Possible Cause
- Steering motor not operating or wired incorrectly.
* Check wiring and condition of steering motor.
- Faulty steering module.
* Replace
- Faulty feedback encoder (ECR2).
* Replace
217
This status code is displayed when there is no steer wheel movement upon command.
Steering disabled
Possible Cause
- Steering motor not wired
* Make certain motor is connected
- Feedback encoder (ECR2) disconnected
* Make certain encoder is connected to connector module and the connector module to the steering module.
- Steering motor faulty
* Verify motor condition
  • Posted 26 Jan 2018 02:34
  • Modified 26 Jan 2018 02:35 by poster
  • Reply by mike_v
mike_retired
Hi How did you go with the code 217 i have the same code coming up unit will drive and just cut or or sometimes it just want drive even after start up i have 2 codes
217
208 i believe this is a steering code
  • Posted 22 Jan 2018 16:12
  • Reply by jeffrey_b
Cheers Jeff
I have a Stock Picker,
Crown SP3000 Serial is 1A237714
showing code 217
Does anyone know what this might be???
Thanks in advance
  • Posted 3 Oct 2017 05:53
  • Reply by ufl1996
  • Tennessee, United States
Those fault codes deal with steering so I do not think that is your problem. What does the battery display show? If it is all the way down and flashing it is in lift lock out.
  • Posted 1 Oct 2017 10:45
  • Reply by popeye
My Crown SP 3000 forklift has been sitting parked for a while with the battery fluid below the level. I have filled up the battery compartments with Sulfaric Acid and topped them of with the distilled water. I charged the batteries up overnight. The forklift is driving, however the platform with forks does not go up or down. I read the error codes 203, 213 and 216. What do the indicate?
  • Posted 30 Sep 2017 01:33
  • Reply by AlexStas
  • Alabama, United States
Alex Stas
are you check it up, the power cables? or the conection to the power fuse at the positive cable? also the fuse maybe have a false contact internaly.....
  • Posted 31 Oct 2013 10:21
  • Reply by raul_s
  • San Luis Potosi, Mexico
the ev100 card is the brand and model nomenclature for the GE traction logic and semiconductor oscillation control card, which is mounted pretty far back up in this unit and not to be messed with unless you have had considerable training in the related safety issues of working on one of these controls. I would not be the least bit concerned, at this point, about "dry" solder joints, These cards are about 100 times more likely to have a connecting wire die of old age and vibration rather then the solders internal to the card to cause a problem
Are you waiting 8 hours after the charge cycle stops before operation of the truck? this is a 'must do'.
You may be able to set your charger to not charge quite so hot, rather than readjust the truck.
  • Posted 26 Oct 2013 08:43
  • Modified 26 Oct 2013 08:51 by poster
  • Reply by edward_t
Thanx Edward t, the voltage was at 26.3volts yes it is a 24v battery, a friend also said to remove the traction card it possibly could have dry solder joints, what is the ev100? you speak of? After further investigation this happens all the time with this truck after charging, I used the lift motors cause they were the only thing still usable the forward n reverse were the only things not working after lifting n lowering for a bit to bring down the battery voltage the truck was then drivable :)
  • Posted 24 Oct 2013 21:27
  • Reply by thetine_m
Cheers Matty
Your local Crown dealer will be the only 'correct' place to acquire manuals. We can only discuss portions of the manuals, and things we know from experience.
Code 16 refers to the battery being over charge. you will need to fix this before you will be able to go any further. what is the 'at rest' battery voltage? you may have to use an ev100 handset to set the card to the actual voltage of the battery. (are you sure you have a 24volt battery in this truck?)
  • Posted 24 Oct 2013 19:56
  • Reply by edward_t
edition #1235 - 19 June 2025
